Levulinic Acid on an HP-5 column?
Posted: Tue Dec 18, 2012 9:56 pm
So I've been running a few samples of Levulinic acid on an agilient HP-5 column. No problems with separation or detection but I am concerned that it might damage the column long term since I am running an acid through the column.
Does anyone know for sure?
I should also mention that I am running hydrogen as a carrier gas. Inlet temp 280, oven temp 180.
