surrogate concentration in the calibration standards
Posted: Mon Dec 17, 2012 7:57 am
Dear All,
I am quantifying PAHs in soil using an HPLC/UV. The procedure I am using is based on ultrasonic extraction then a silica column clean up. I am planning to use Decafluorobiphenyl as a surrogate standard to check for any losses during the procedure.
Is there any rule or common practice to decide what concentration should be added to the samples and to the calibration standards?
I found some methods use a fixed concentration in both samples and calibrators but others generate a calibration curve for the surrogate.
Any ideas or experiences are appreciated.
Many thanks in advance.
