Make-up gas flow rate on HP 5890
Posted: Fri Dec 14, 2012 3:39 pm
I am pluming an old HP 5890 ( not 5890A, not 5890 series II) with FID.
Use helium as carriers gas, while nitrogen as make-up gas.
I am checking the flow rate of gas supplies without running the GC/detector. The problem is the nitrogen makeup gas does not have any flowrate
when I plugged in the bubble flowmeter into the FID outlet.
I think it is abnormal. I did not find anything in the GC manual to say one way or another, but I suspect that the control valve for the carrier gas is broken.
Anybody has experience on similar problems?
