What is the biggest difference in using the Shimadzu QP2010-Ultra compared to the QP2010-SE? I understand that the Ultra has better specs, better sensitivity, and is a higher-end model (between those two). The question I have pertains to academic and research use. Why would it be better to go with the Ultra if the SE can give data that would be good for basic lab experiments? Would the SE be just as good for research?
Any help would be great.
