Chemstation Do List Export to File
Apologies if this has been covered already.
I am trying to set up a Do List in Chemstation to mimic the process of going to Quant -> Generate Report -> Checking only "File" for a Summary report (any filename will do).
We are using Chemstation version D.01.02.16 for what that's worth.
If something is unclear or I need to provide any more information, please let me know.
Thanks in advance for any advice!
I believe this version of the chemstation will put a copy of the quant report in your data file directory by default. check to see if "epatemp.txt" is in the data file (.D) directory. All the versions I use from D.00 onwards will do this anytime you generate a report.
