problem with chiral column
Posted: Thu Nov 29, 2012 8:50 pm
when switch from reverse phase to normal phase, I did not flush IPA enough. so there should be water and ACN present in the column. After that, I can never reproduce my previous result. So should i flush column with IPA overnight?
