How to improve signal on a shimadzu LCMS-2020
Posted: Wed Nov 28, 2012 6:28 pm
Dear all,
Our team just acquired a Shimadzu LCMS-2020, since we’re new with LC/MS systems we’re having trouble to ionise our products. To start I wanted to analyse products such as guaiacol, vanillin and cinnamic acid. We achieved a good separation on the HPLC (detected with a PDA), but for the MS part I only see noise. We are using water/acetonitrile as a mobile phase. I tried caffeine and we obtained a better signal but for my products cited above the ration signal/noise is very low, and I’m not sure if I ionise properly my products. I saw on a paper [1] that ammonium formate could improve ionization (besides being a good buffer). Has anybody been working with a LCMS-2020.
Thank you for your help
Cheers
[1] Owen BC, Haupert LJ, Jarrell TM, Marcum CL, Parsell TH, Abu-Omar MM, et al. High-Performance Liquid Chromatography/High-Resolution Multiple Stage Tandem Mass Spectrometry Using Negative-Ion-Mode Hydroxide-Doped Electrospray Ionization for the Characterization of Lignin Degradation Products. Analytical Chemistry. 2012 Jul 17;84(14):6000–7.
Cheers
