inter-day reproducibility of GC-MS
Posted: Wed Nov 28, 2012 5:31 pm
I know very little about GC-MS. I have a situation where someone ran a lot of derivatised samples, and then a few days later realised they would have liked to quantify the samples against an external standard calibration, so they derivatised a standard, diluted it to various extents, and injected the dilutions, with the intent of using this curve on the previous samples. Naturally the results are far from perfect, and they're interested in which steps are most likely to be causing the trouble.
As someone who runs LC-MS, my stock answers would have been that what they're doing would give a rough estimate in HPLC-UV because UV absorbance is a physical property that shouldn't vary from day to day, but it would be utterly hopeless in LC-MS because ionisation changes over time. In GC-MS I don't know the answer. How variable is ionisation efficiency from one week to the next? How variable are the injections (if the liner gets dirty, does this affect the amount of the injected material that gets onto the column)? Is it safe to derivatise the samples on one day, and the standards another day, or is derivatisation efficiency variable? There are so many things I don't know! Heeeelp!
