Seal Wash
Posted: Mon Nov 26, 2012 3:13 pm
by StephenO
When using the Waters 2695 Autosampler does the Seal Wash actually enter into the Mobile Phase during a HPLC run (can seal wash affect the chromatogram) and how often does the system carry out a seal wash?
Thanks in advance
Re: Seal Wash
Posted: Tue Nov 27, 2012 9:52 am
by aceto_81
On a normal functional 2695, the seal wash is separated from the mobile phase system.
And as the mobile phase is at a much higher pressure than the seal wash, it's more the other way: the mobile phase leaks into the seal wash waste.
I think the default cycle time for the seal wash is 1 minute (you can set this manually)
Ace
Re: Seal Wash
Posted: Wed Nov 28, 2012 11:46 am
by StephenO
Thanks Ace
Re: Seal Wash
Posted: Fri Nov 30, 2012 12:53 am
by Bull76
If the seals are defunct then the seal wash can enter the mobile phase. Are you having an interaction based on the seal wash and your mobile phase combustion?
