Changing units to mV*sec for area in Empower 2
can i change the unit for area from microV*sec to mV*sec in empower?if yes, how!?!?! i just couldn't figure it out :(
I think you would need to create a custom field (area*1000).
thank you for your kind reply...i thought maybe there's a setting that i'm missing...guess i'll have to create a custom field for that if i can't find any other solution. it's just that even tough i've read about how it's done, i have never done that. if i'll need help maybe you'll be able to give me some tipps with how to do that.
thanks again
And you after all these years you don't get correct units as default.
Just an obsevation, but if you multiply the area (µV/sec) by 1000 that will give you nano-V/sec
Surely it should be Area/1000 for mV/sec :|
Yes, that's right....Area/1000 ...thanks for your replies...haven't had time to try making a custom field, and donno if i will have any this week...maybe towards the end of the week. any other suggestions are still welcome :D
