0.53 precolumn on a DB-5 0.32 column
Posted: Thu Nov 22, 2012 11:38 am
I am doing a determination of waxes in oils with 10 meters of DB-5 0.32 column with an on column injector.
I was wondering if adding a 0.53 deactivated fused silica precolumn (to facilitate the use of larger diameter syringers for the on column injection) in front of the column could interfere with the analysis or the way the sample goes into the column.
Could you think of anything against doing this analytically-wise?
