Shimadzu SPD-M10avp Chromeleon 6.8 SR11 WinXP
Posted: Wed Nov 21, 2012 10:52 pm
by nitrendipin
Hello! I've been trying to install a SPD-M10avp PDA on Windows xp. Whenever I try to install the driver manually i get a blue screen. However after rebooting the computer there is an unknown device listed in the hardwaremanager in the subdirectory of shimadzu devices. Still the detector does not communicate with either Chromeleon or Class VP. Does anyone have an idea how to install that detector driver correctly on Windows XP?
Anton
Re: Shimadzu SPD-M10avp Chromeleon 6.8 SR11 WinXP
Posted: Thu Nov 22, 2012 9:12 am
by dblux_
Isn't it licence issue ?
Posted: Thu Nov 22, 2012 1:42 pm
by ACrawshaw
Hi nitrendipin,
dblux is probably correct. Do you have all the neccessary instrument and user licenses to access Chromeleon and also control your instrument?
The first thing to check is do you have a license dongle for Chromeleon? (Green USB).
Posted: Fri Nov 23, 2012 8:06 pm
by nitrendipin
Thanks for the replies. We have a timbase class three license provided by a license server in our unit. When configuring the instrument setup in the chromeleon server configuration I can install the DAD without getting any error messages. The question is if the device is recognised by windows at all. The hardware manager lists an unknown device under shimadzu instruments. Could it be a driver problem?
