Small organic acids on Hypercarb
Posted: Sun Nov 18, 2012 10:39 pm
by MiMa987
Hi, i found that citric acid could be determinate on hypercarb column. Does anyone have experience of analysis small organic acids on this column?
Or is Hilic column better choice?
Re: Small organic acids on Hypercarb
Posted: Mon Nov 19, 2012 11:05 am
by Gerhard Kratz
For citric acid many applications are available, on different column brands. All depends on the matrix effects you might see on different brands, different chemistries. And at the end of the day price is also important.
The column you use is an excellent column. I'm sure many other chemistries, for example HILIC, will give you also excellent results. Just screen the application databases of some column manufacturers.
Posted: Mon Nov 19, 2012 1:24 pm
by Coffo
"Ion exclusion" is often used for organic acid separations. Nice simple technique - isocratic elution, low flow rates, straightforward detection. Sorbents are usually relatively soft sulfonated polymers so it is usually necessary to run at elevated temperature. Plenty of vendors sell this type of column and they usually provide a list of retention times for different organic acids, so it should be fairly easy to choose the column most suited to the separation you are trying to achieve.
Posted: Mon Nov 19, 2012 3:27 pm
by Consumer Products Guy
We formerly used ion exclusion columns for citric acid and citrate. About 6 years ago we started using specialty columns called "organic acid columns", better.
