How to regenerate the column
Posted: Sat Jun 25, 2005 8:41 am
Hi to all,
Here i want to regenerate the column, which is having normal pressure while running the mobile phase but only thing is peak shape is not good, if i use new column peak shape is good and sharp.
So some of my collegues said that regenerate the column even though column pressure is not exceeded.
My column is 250X 4.6 mm length, C18, 5 micron column. Can anybody help me?
