dC18, TEA / TEAP, ZDA
Posted: Thu Oct 25, 2012 7:25 pm
Hello friends-
I am developing a method to resolve Zoledronic Acid from its impurities using a pH 3.5 aqueous mobile phase (H2O with triethylamine pH'ed to 3.5 with H3PO4) and using a Waters Atlantis dC18 column.
I am having the following issues, and wonder if anyone has any insight?
I seem to lose response over time, sometimes including completely absent peaks for PQL injections.
Can TEA or TEAP destroy the dC18 stationary phase over time, and can these columns be regenerated?
Also, I sometimes see negative peaks and strange system peaks in blanks with clean mobile phase. Does the grade of TEA make such a huge difference? Are there specific impurities in TEA (or TEA itself) that can interract with zoledronic acid and / or the column so strongly?
Any other thoughts about zoledronic acid in general?
Thank you!
Thank you!
