Chemstation- fatal sequence error
Posted: Thu Oct 25, 2012 6:36 pm
by mplasters
My sequence will start and run line 1 to completion, then an error messge pops up "fatal sequence error-- see Log book." The log book has no notation. Data analysis states no data was received for said data file. Agilent's site isn't helping. G1701EA. Can you help?
Re: Chemstation- fatal sequence error
Posted: Thu Oct 25, 2012 7:07 pm
by Archimonde1308
Try using the "Simulate Sequence" function. Be sure to select the "Entire Method" option when running the simulation. It is very useful for debugging sequences. (I use a similar version of chemstation)
Posted: Fri Oct 26, 2012 12:48 am
by cleh
Make sure you have adaquate space on your hard drive.
