GC Chemstation/Openlab version C--Finding your runs
Posted: Wed Oct 17, 2012 1:00 pm
I am currently working on setting up Agilent Openlab software to use to replace Galaxie CDS. While Galaxie was fine for what we needed, we could not get the drivers for our new GC and 7693 autosampler. Long story short, Is anyone having trouble remembering what sequence they ran thier samples in?
I work in a QC lab which runs anywhere from 2 to 50 or so runs a day on a single GC in a single sequence (usually named with the date). In Galaxie, to find a sample run, all I had to do was go to Open chromatograph, pick the directory and select it. This was great. However, with this new sequence container (result set) we are required to first search for the .d files in windows and then find the sequence in which the sample was run. I have tried using openlab with sequence container turned on and turned off. Both still require searching in windows to find the sequence containing the sample.
I also investigated writing a macro to create the directory to my liking but am unsure what files to copy to the new directory in openlab. Hopefully someone can point me in the right direction.
