I don't have any experience with microwave extraction, but we did buy 2 used ASE 200s last year due to a large increase in our sample load. When they work, it beats soxhlet for time and solvent use, but we spend alot of time repairing valves and clogged lines. Also not impressed with Dionex's tech support and user's manual, we end up guessing where the problem is. They may have fixed these issues with their new unit, but can't get an answer from the sales rep either.
Preparing the samples is the hard part with this unit, you can't just mix it with sodium sulfate and go, it requires careful mixing with diatomateous earth and packing into the cell.
I hope another company comes up with a version of this technology, Dionex charges a premium for their monopoly, although some of the accessories can be found through Restek or Environmental Express.
Also, Envrionmental Express has a version of the proven Hot Block for use with organic solvent instead of microwaves.
http://www.envexp.com/products/4-Organi ... Extraction
Unfortunately, it is not specifically addressed in EPA methods, so there may be a problem with accreditation.
Keep on Preppin'!
