Problem with FID baseline
Posted: Fri Oct 05, 2012 8:09 am
Hi Everyone,
I had my FID repaired this week because it would not ignite. The repair was successful and it ist working again...except for the results. The Baseline is constant at about 40000 counts. I have run now two sequences since the repair. Both hat the high baseline except in the first one after 27 injection the baseline fell to normal again....then I had to change Hydrogen an the baseline came again up but not as I hoped again falling after some injections....it is nailed at 40000 counts. I have checked the system for leaks but everything is ok.
What could it be......??
Some details about the system: HP 5890 Series II with split splitless injector, FID, DB-XLB 30m*0.25*0.5 and an TSG-530660-P (10m*0.53 coated with OV-1701-OH), carrier gas H2, and splitless injection of 1 microliter silanized componets (wine in our case).
Would be grateful for any help
Cheers
Andreas
Cheers
Andreas
