Sticky needle
Posted: Wed Sep 26, 2012 12:44 pm
We are having an issue with the Combi-Pal auto sampler attached to our G.C. After injecting the first sample the bottom of the lower needle guide does not drop back to the bottom of the needle, but "sticks" about 2cm up, which leaves exposed needle. This affects the Z value of the sample tray (the needle does not reach the sample vials or injector, resulting in "object not found" error). I would like to know if I can loosen the screws, or grease the metal arms to ensure the guide returns to the bottom of the needle.
Nat
Nat
