Changing oil cartridge on HP5970B turbo pump
Posted: Tue Sep 18, 2012 2:13 pm
I have a HP5970B detector with a rebuilt turbo pump from 1998 that had been running well up until it got very infrequent use in the last couple years. I'm debating whether to change the oil cartridge in the turbo pump before bringing the instrument back up and was wondering if anyone had experience doing this service.
It requires flipping the detector on it's back and removing the bottom plate of the turbo. There's a oil cartridge and wick for the turbo bearings that can be gently pried out and replaced at very modest cost. Refitting the bottom plate on the turbo re-seats the cartridge at its proper position.
My inclination is to not fix it if it isn't broken and there's a risk of introducing debris into the turbo attempting this maintenance. Then again, this seems like a straightforward operation to do.
Any thoughts or tips on this would be greatly appreciated.
