Baseline drift when use THF
Posted: Tue Sep 18, 2012 1:03 am
Dear all HPLC guru,
I am currently encountering an issue of baseline raise when I use THF in mobile phase B. The details as below:
1. Zorbax Bonus RP , 150mm column
2. Mobile phase A is 0.1%TFA, Mobile phase B is THF:ACN at 1:1
3. UV 278nm
4. Gradient is initially MPA is 86% : MPB 14%. After 15 minute, MPB increased.
I realized that when the MPB starts increase from 15 minutes, the HPLC chromatogram baseline suddenly start raise. The THF i use is without stabilizer for HPLC grade, and I am using the amber bottle for MPB.
Any body can share the experience on this?
Thank you thank you!
3. UV 278nm
