hplc of plant sample
Posted: Mon Sep 17, 2012 8:47 am
by kshiprakapil
Dear all the members
can I use chloroform:methanol:diethyl amine in ratio of 90:10:0.2 respectively as mobile phase in c18 column for hplc analysis. I need some papers where chloroform was used as mobile phase with c18 column.
thanx and with regards.
Kshipra Kapil
Re: hplc of plant sample
Posted: Wed Sep 19, 2012 9:23 pm
by Jack Silver
I'm assuming silica-based C18 as polymeric resins might swell with these solvents. Chloroform and other organic solvents won't hydrolyze the C18 and can be used to clean the columns.
You can run non-aqueous reverse phase, referenced in referenced in Practical HPLC Method Development,Snyder, Kirkland, Glajch, 2nd edition, p.267.
I have run non-aqueous reverse phase on flash columns using acetone, dichloromethane, and ethyl acetate.
Here are some app notes/posters I've done on the subject:
http://www.isco.com/WebProductFiles/App ... idants.pdf
http://www.isco.com/WebProductFiles/App ... ld_C18.pdf
In the interest of full disclosure, I work for Teledyne Isco.
