Sulfonate & Disulfonate derivitisation
Posted: Fri Sep 14, 2012 4:14 pm
Hi all,
Me and my colleague have been asked to look into the development of a method for low level detection (<50ppm though ideally <10ppm) of a disulfonate compound MMDS (methylene methane disulfonate).
The compound in question does not absorb at a useful UV wavelength for UV detection and so the method I am using for the determination of MMDS in large concentrations involves an RID. As I am sure you are all aware the RID is not a very sensitive detector and tests I have carried out so have led to an estimated LOD of 0.1% (way above the concentrations my superiors have in mind!).
I was wondering if anyone has any experience with regards to the analysis of sulfonate compounds and could suggest a derivitisation agent I could perhaps try so that UV detection can be employed in place of RID.
As ever any information provided will be very much appreciated.
Kind regards,
James
Kind regards,
James
