Empower Custom Field question
Posted: Wed Sep 12, 2012 9:51 pm
by michaelbarnes42
Hello all,
I have a crazy question. I am pretty good with Empower, and can ussually make the custom field I need, but I have never had to do this before.
I have an HPLC run using an internal standard. The internal standard is processed at 334 nm and the analyte is at 262 nm. I would like to create a custom field that is just the (Analyte peak area @ 262 nm)/(Internal standard peak area @ 334 nm)
Any empower experts that know how to do this, and could give me a tip it would be great.
Re: Empower Custom Field question
Posted: Thu Sep 13, 2012 7:24 am
by aceto_81
Not tested, but I think you can assign channels to your peaks in your components table.
This way you can set your internal standard as usual as internal standard for your analyte.
And I think response is the custom field where you are after for.
Ace
Posted: Thu Sep 20, 2012 4:49 pm
by michaelbarnes42
Thanks for the reply, it wasnt exactly what I was trying to do, but it does do the job.
Posted: Fri Sep 21, 2012 8:39 am
by aceto_81
or by using a timed wavelength?
And make a customfield for the division, which are now on 1 data channel?
Ace
