elsd configuration
Posted: Wed Sep 12, 2012 6:47 pm
by biom
Hello everybody,
I have an Agilent 1200 ELSD detector that has been previously connected to a preparative HPLC 1200. now I would like to transfer de detector to an analytical HPLC 1200 but the chemstation does not recognize the new module. Can somebody help me please? I have already change the configuration of the chemstation "off line" successfully but when I launch the chemstation "on line", the elsd module does not appear on the list of the instruments. What I need to do or what I'm doing wrong?
Thank you!
Re: elsd configuration
Posted: Wed Sep 12, 2012 7:22 pm
by Consumer Products Guy
I'm assuming that you have the LAN cable or remote cable hooked up from the ELSD to the existing HPLC stack/module.
So next question is: is the firmware of the ELSD module compatible with the rest of the stack? Mismatches can cause such issues.
I also assume that you powered all modules and the computer off, and re-started all.
Posted: Wed Sep 26, 2012 6:51 am
by Uros
If my memory serves me right, you have to install drivers for ELSD, also the normal RS-232 cable is not working, it has to be from agilent (I think that some pins are switched).
