Anyone do Amino Acid analysis using deriv GC/MS methods
Posted: Thu Aug 30, 2012 9:55 pm
I was wondering if anyone here has experience doing the amino acid analysis gas chromatography methods. I came accross a couple including Phenomenex's kit a method using simple derivitization with propyl chloroformate
http://epub.uni-regensburg.de/12318/1/H ... 090719.pdf
A Sigma Aldrich method using N-tert-butyldimethylsilyl- N-methyltrifluoroacetamide to derivitize them.
I am looking for a method that is fairly simple, robust, and cheap. A lot of the methods use isotopic dilution which I'd rather avoid that and just use norvaline as an ITSD if it is reasonably accurate.
