Basics for using the Waters Empower software
Posted: Thu Aug 30, 2012 6:59 am
by debpilot
Does anyone have a cheatsheet for using the Waters Empower software. (Using UPLC with PDA) :?
I just need the very basic steps for setting up a method, calibration curves, running samples and then retrieving data.
I used Millenium software about 8 years ago but was not proficient.
Re: Basics for using the Waters Empower software
Posted: Thu Aug 30, 2012 7:43 pm
by LC_labrat
I would start by using the wizard function to help you re-familiarize with the software.
Posted: Fri Aug 31, 2012 6:56 pm
by JGK
Waters do/did supply an interactive tutorial CD thaty did what you ask
Posted: Sat Jan 12, 2013 8:00 am
by EldredJonas
Here's one: http://franklin.chem.colostate.edu/dive ... 1203rA.pdf
Waters has some cheap web based training too if you're interested.
WATERS 1525 PUMP OPERATION VIA ETHERNET IN Empower2
Posted: Fri Jan 06, 2017 3:39 pm
by fareedtayyeb
I AM SURPRISED TO SEE THEY SAYS INTO THE EMPOWER 2 SOFTWARE CONTROL VIA ETHERNET FOR VER 2.11 ^ 1.60 BUT ON ICS INSTALLATION THE DEPLOYMENT MANAGER INDICATES MAC , ISP DEFAULT AND ALTERNATE BUT NEVER ENABLE THE 1525 SELECTION WHICH IS BLANK INSTEAD OF IT SHOULD DISPLAY WITH SERIAL NUMBER. WE PERFORMED 2489 DW DETECTOR MONTHS AGO WITH EMPOWER 2 IT WAS ALSO CATCHY IN THE FIRST PLACE BUT RESOLVE THE ISSUE BY INSTALLATION WINDOWS NETWORKING TO RUN DOWN DEPLOYMENT MANAGER WHICH WATERS NEVER MENTIONED FOR WIN xP INSTALLATION.
CAN ANYBODY HELP OR GUIDE TO GIVE A PUSH TO US
THANKS
TAYYEB
