from MassHunter to ChemStation
Posted: Fri Aug 24, 2012 12:43 pm
by dRima
Good day, collegues!
I have a one simpler question! How i can convert collected datafile from the MassHunter (Agilent GC Q-TOF) to the ChemStation format, or for AMDIS?
Can I just do something.
I just need to make spektrab deconvolution using AMDIS. This program only accepts files collected from the program ChemStation.
Thank you!
With best regards!
Dmitry
Re: from MassHunter to ChemStation
Posted: Sat Sep 15, 2012 10:18 am
by WHLab
Hello
The only way I found to open MassHunter files with AMDIS is to export the .D (MassHunter format) file as mzData format.
I open the file in Qualitative Analysis and export it as mzData (File -> export -> as mzData). In the options window that appears, you can specify the location that you want the file to be saved.
Posted: Mon Sep 17, 2012 7:46 pm
by dRima
Hello
Hello! Thank you very much! This is very useful information! I know how to export it as mzData, but i don't know, that this is works for the AMDIS. Hm, it;s good. I'll try to do it tomorrow.
With best regards!
Dmitry
