Chromeleon Server Monitor Error
Posted: Tue Aug 21, 2012 2:07 pm
I am running Windows XP SP3 on a Dell 755 and install the software without any errors. When starting the Chromeleon Server Monitor it says the Chromeleon Server is Starting but get the following error. CmMon Could not start CmDriver: The dependency service does not exist or has been marked for deletion. In the event viewer I did see the following error also: The Chromeleon Driver service depends on the following nonexistent service: HardLock. Has anyone run into this issue and is there a fix. The software version I am running is: 6.50 SP1. Thank you for your help.
