I need to do an analysis of several organic solvents....hexanes, isopropanol, ethyl-alcohol, and DMAE. I am using a DB-5MS column and do not have FID or headspace system. I know that these solvents are all soluble in acetone...so i planned to spike the acetone with approx 20uL of each solvent and then running it using a high split ratio and oven ramp temps set to separate each according to individual boiling points. So far I have had little success as was curious if this was ideal for the instrument i have??? Agilent GC (think 5973) with MSD (single quad) EI.
Hi, first of all you are using the wrong instrument but you already know that, i'm just remarking it.
With a DB-5 it's impossible to separate acetone from 2-propanol, especially if you use acetone as a solvent with a very big peak.
Try using
Carbon Disulfide as the solvent and you should be able to reach your goal.
Tinjector: whatever you like as long as it is above 150°C, try 250°C
Oven: 40°C for 1 min
100°C (200+? i don't know your highest boiling compund) @5 °C/min
keep transferline and analyzer at a temperature above the highest oven temperature but not too high, you don't want your compund to leave the detector too fast. If it was an Ion trap i could recommend some temps but since is a quadrupole i suggest you to ask someone more competent for the analyzer temperatures used for solvents determination.
split ratio: as higher as you can (at least 1:50), using GC/MS you should avoid to read the solvent peak, the risk to burn the EI filament after several run is high.
Following the above conditions and with your column you will find the compunds in this order and baseline separed:
methanol, ethanol, 2-propanol, CS2 (solvent), 2-butanone, ethyl acetate, isobutanol, n-butanol, benzene+cyclohexane, methylisobutylketone, toluene etc. I don't really know where hexane will elute, it should be far from CS2 and maybe after butanols.
Anyway if you plan on analyzing more compunds consider purchasing a "putcompanynamehere"-624 column with a thick film and make a favor to your MS and buy a FID, they are very cheap these days.
Good luck.
