Two components one %CV problem
Posted: Mon Aug 20, 2012 4:21 pm
Hi
I am experiencing problems on Waters 2695 with 2489 Detector, I am intermittently seeing sample sets which are failing the system suitability or bracketing standard criteria because the %CV is to high.
We first noticed this when analysing single components, When carrying out six injections from the same vial maybe one of the injection areas would of been significantly higher than the rest of the injections causing the high %CV.
We can now exclude the injector as we are noticing the same thing in multi-component methods but only one of the components is effected and the other is fine.
Anybody had any experience of this problem before
