Chemstation help
Posted: Mon Aug 06, 2012 10:41 am
Can someone tell me how to do the following in Chemstation:
1) Calculate totals, averages, SDs and % RSDs for data from different sequences
2) Set up a calibration to identify unknown sample peaks, but not quantitate them (for qualitative analysis, where there's no standard run, just wanna calc the % area of each peak).
3) How to display the corrected migration times in the "Data Analysis" window - either in a table, or the electropherogram, or anywhere at all
4) In Calibration, how to change the mobility reference peak settings (without starting over with "Insert New Calibration Table")
5) Can I change the preset report formats (I'm guessing not). Then how do I access some of those tantalizing columns (like k', resolution, etc) in the plain old "Report Layout"
Please help! It seems quite intuitive with Empower (or at least can be figured out from the Help), but I'm going slightly crazy with Chemstation
Chemstation B.03.01, using it with a CE.
