how often do you replace buffers?
Posted: Thu Aug 02, 2012 2:09 pm
I'm sure this has come up loads of times but I couldn't think of a sensible search term... sorry!
I replace aqueous buffers every few days, and usually run them in gradients with pure methanol or acetonitrile, which I replace only when empty. Now I'm starting to run more methods where I'm making up aqueous-organic mixes with buffer, e.g. 1:4:5 50mM ammonium formate pH 3.2:water:acetonitrile. I'm using a hideously expensive grade of acetonitrile because Waters complain about background ions in LC-MS if I don't, and I don't want to throw away acetonitrile solutions.
How often do you recommend I change acetonitrile-containing buffers of ammonium acetate or ammonium formate? Sorry if this is a silly beginner question. Thanks for any help!
