We are having a problem with the way ChemStation B.01.01 is reading the archiving bit. If we hit the Chem32 directory with SDMS, Veritas, or any utility that flips the archive bit ChemStation thinks the file is no longer there. It even fails the installation verification.
Has anyone else seen this? Anyone found a registry hack or anything to get ChemStation to ignore the archive bit?
Tom Mizukami
