regarding two compounds having same Rt
Posted: Mon Jul 30, 2012 6:03 am
by rrm1987
I am currently working on Metal complexes and its seperation in HPLC.Individually i analysed the metal complex.Three metal complexes has same Rt.How to seperate this?
conditions are:FR=1mL/min(isocratic);Mp=CH3OH:THF:Buffer pH-6=30:30:40;C18 Luna from Phenomenex.
Suggestions required to slve this issue.
Re: regarding two compounds having same Rt
Posted: Mon Jul 30, 2012 6:21 am
by Gerhard Kratz
2 things I would try first:
play around with pH of your buffer - acidic and basic
try a HILIC column
Good luck
Posted: Mon Jul 30, 2012 11:43 am
by prepcolumn
what are your complexes?
Posted: Mon Jul 30, 2012 12:05 pm
by Vlad Orlovsky
A lot of metal complexes do not survive chromatography. It is possible that whatever you see is a portion the complex (organic molecule) and if it the same for all three you might see only one peak,
Posted: Tue Jul 31, 2012 5:06 am
by rrm1987
What would you suggest me to go ahead in seperation of those complexes?
Posted: Tue Jul 31, 2012 6:52 am
by Kristof
Regarding complex stability in chromatography - if those compounds form complexes with the same metal, would adding metal salt to mobile phase help?
[edited for clarity]
Posted: Tue Jul 31, 2012 12:32 pm
by rrm1987
the same ligand complexed with different metals not same metal complexed with different ligands.
Posted: Tue Jul 31, 2012 12:54 pm
by rrm1987
Cobalt and copper complexed with quinolyl azo dimethyl amino phenol
Posted: Tue Jul 31, 2012 3:36 pm
by prepcolumn
Check the paper at this link.
http://www.ncbi.nlm.nih.gov/pubmed/12509050
If you think that it works and cannot reach full paper let me know
Posted: Tue Jul 31, 2012 5:17 pm
by Vlad Orlovsky
What is the task? If you task is to quantify each complex you can look at cobalt and copper in ELSD, and your ligand in UV and do calculation on each complex assuming that you know structure of the complex and you don't have excess of free metal ions and free ligand floating around.
Posted: Wed Aug 01, 2012 6:36 am
by rrm1987
i tried that method.That method was reproducable.
Posted: Sun Aug 05, 2012 6:01 am
by rrm1987
i am planning to quantify Cu,Co,Zn,Mn and Fe simultaneously in single run.will this method help?
