Chiral Column That Can Show a Reversed Phase Mechanism
Posted: Tue Jul 24, 2012 11:44 pm
Hello all
I'ld like to throw a question out there for the group. Is anyone aware of a chiral column that can also act as a reversed phase column?
The reason I am asking is that we are trying to develop a separation between our API, its chiral epimer, and the other deg products. Since the epimer is a diasteromer of the API it is theoretically possible to do this with a standard reversed phase column, however in practise it is somewhat difficult.
So I was thinking that if there is a chiral column that could also be used as a reversed phase column this might give a little more separation (for something like a diastereomer).
Just to clarify, I don’t just mean that we would run it in "reversed phase mode" (a term often used in the chiral world to mean that we're running it with reversed phase type solvents), I mean where the column is actually giving a reversed phase mechanism of separation. I took a quick look at all the different types of chiral columns that exist and I thought the antibiotic columns might be the best bet. But I'm not at all sure.
Any suggestions would be much appreciated.
Thank You
Thank You
