Controlled Atmosphere vials and seals
Posted: Sat Jul 21, 2012 4:36 pm
Howdy Fellow Chromatographers!
I am looking for a semi-specific item to support some stability testing. We are trying to investigate the performance of some of our materials under controlled atmospheres, such as all N2 or a fixed volume of air. The key attribute(s) is that these vials are impermeable to gas leaks from -20C to 60C. The secondary attribute is volume--it would be good for these containers to be capable of holding at least 20 mL of fluid, but 40 mL would be even more ideal. Finally, materials compatibility is close to that of limonene (viton or teflon seals are appropriate). I know there are some options with secondary bagging of vials or flame-sealed ampules, but our volume of samples is much too large for those approaches to be practical. I am currently discussing options with some GC consumables manufacturers--headspace vials with crimped seals seem like a potential approach.
My humble request to you, the brilliant and experience chromatographers/scientists on this board, is to point me towards some containers that will achieve what I am after. If there are any questions, please don't hesitate to ask.
I appreciate any advice you may have! Thank you SO much in advance.
