Moving Chemstation configuration data to another PC
Posted: Sat Jul 21, 2012 12:57 am
by LabIT
Hello, Chromatography Forum.
Let me start by saying I am new to the forum and work as the IT manager for a laboratory. I apologize if my terminology is incorrect in relation to Chromatography from time to time. Please bear with me.
I have quite a list of items that I need assistance with and have so far learned a great deal from browsing the forum. The most pressing issue as of right now is getting a particular workstation back up and running. The workstation's motherboard went out and I have since set up a new PC with Windows XP SP3. I need to reinstall Chemstation B.01.00 and configure it for use with an ISA GPIB card, 7673 controller/injector and a 5890 GC.
First of all, will this configuration work with XP?
Previous PC was running Windows 2000 with the same hardware/Chemstation setup.
Second of all, the old PC is actually only half dead. I can still boot it to Windows but it will only stay stable and usable for 15-30 minutes and then suddenly reboot.(Capacitors on motherboard are failing) Is there any way I can copy the Chemstation config from the old PC to the new one? So the technician does not have have to manually re-define her methods/settings?
Re: Moving Chemstation configuration data to another PC
Posted: Sun Jul 22, 2012 11:54 am
by dblux_
... Is there any way I can copy the Chemstation config from the old PC to the new one? So the technician does not have have to manually re-define her methods/settings?
First of all simply backup 3 directories where ChemStation stores Methods, Sequences and Data.
Then you probably may open ChemStation configuration editor and see configuration settings. Don't forget to have licence number when installing ChemStation.
Although this document deals with rev. A, it might be of some help to you:
http://www.chem.agilent.com/Library/Sup ... a10572.PDF
Posted: Mon Jul 23, 2012 1:49 pm
by LabIT
Exactly the type of info I was looking for.
Thank you very much.
