Determinining the purity of solvents
Posted: Thu Jul 19, 2012 8:55 pm
Hi all,
I have a question regarding purity determinations of organic solvents by GC. To be specific, what is the best method for quantifying the purity.
Based on what I have done and, indeed, been taught in the past I have always thought that the area % method is the best way of assessing the solvents purity. Particularly given that the identity of many of the impurity peaks are unknown. However it has recently been suggested to me that if the identity of a couple of the impurities can be elucidated it is acceptable to calibrate these compounds and, by using the % normalisation method, adjust the response factors of these peaks. All uncalibrated peaks will have a response factor of 1.
This latter method does not seem an acceptable way of proceeding to my mind. However I was wondering if anyone on here had experience of assessing purity this way. If so could you provide any explanations as to why this is acceptable? What would you say is the best way of assessing an organic solvent's purity by GC?
Many thanks,
James
Many thanks,
James
