- admin
- Site Admin
Chromatography Forum: LC Message Board: APCI and ESI ?
By Anonymous on Tuesday, June 1, 2004 - 10:07 pm:
Dear members,
Using LC-MS, I have a complex sample to separation. According reference materials, part of it compostion is easy to ionize in ESI and rest compostions easy in APCI. Could I expect complete the analysis in APCI. In another words, could I ionize those compounds in APCI which is easy to ionize in ESI?
Thank you in advance.
Michelle
By Thomas on Tuesday, June 1, 2004 - 11:26 pm:
Dear Michelle
You have to try it in your lab.
A general answer cannot be given - if it always was possible to ionize "ESI-compounds" in APCI-mode, then why would anyone buy ESI?
Of course there is a possibility, that you can ionize your compounds with APCI, but only trial (and error?) will tell you.
By MG on Wednesday, June 2, 2004 - 01:41 pm:
I agree with Thomas. Some compounds that work readily by ESI, will degrade in the hotter APCI source. Others will work well either way, so it is worth a try.
By Anonymous on Wednesday, June 2, 2004 - 02:13 pm:
Thank you, dear friends!
Michelle
