Nicotinamide Riboside and Hypercarb
Posted: Fri Jul 13, 2012 2:02 pm
I am currently trying to separate nicotinamide riboside on a Thermo Scientific Hypercarb column with the following conditions: A: .05% ammonium hydroxide in 10 mM ammonium acetate and B: .05% ammonium hydroxide in acetonitrile, a flow rate of .2 mL/min, and a gradient from 5% B to 20% from 2 to 15 minutes followed by 20% to 60% from 15 to 27 minutes. I would like to stick with a pH of 8 or above to avoid conversion of other metabolites of interest to their oxidized forms. The problem is that upon going to a more basic pH the retention time of NR shifted to very high organic percentile (greater than 40%) and the peak shape became intolerable with a width of greater than two minutes and incredible tailing. I have tried varying the salt content without any effect as increasing the eluting strength of solvent B by adding more isopropanol (also with no effect). I know that the pH has greatly affected retention here as I originally separated compounds with a pH of 4 to 4.5. This led to a much early and neater retention time.
Does anyone have advice for an ion pairing agent that may help or general LC advice with this problem?
