How to improve peak reproductivity of furfural with IC
Posted: Thu Jul 12, 2012 1:57 pm
Hi!
I used Dionex-IC with carbohydrate-specific column PA1 and electrochemical detector and NaOH as eluent for analysis of this aldehyde, but the areas and the height of peaks are not reproducible. Since furfural is not much soluble, I prepared NaOH eluent with 2% acetonitrile to improve its solubility in mobile phase, but it did not work. Furfural can be measured with GC and LC method, but I want to know if it can be detected with IC.
Did someone work with furfural analysis using IC? Can you give me any advice.
Thank you!
Thank you!
