hope someone can help me figure out how to correctly use autoscheduler to print post-run or buffered run. This integrator is connected to 5890 GC which has TCD and FID detectors. Real time run us TCD and buffered run is FID. I followed the instructions in the manual, buit so far no luck in printing post run peaks. I use same method for real time and buffered run. They both have the same name METH.MET and they are saved in location M:. Maybe methods have to be different for each channel? I don't use any sequence, although while preparing the autoscheduler is is asking for sequence file name and I just pressed enter which automatically assigned the file M:SEQ.SEQ. Not the integrator and GC are communication but post run chromatogram is not printing.
Any idea where I am making a mistake or any other suggestion would be very very apprecatied. I need my post run badly
I think a BASIC programmer is needed to link auto scheduler to print post run. Anyone knows what to type...I don't know BASIC language.
Thanks, Mikki
