Empower 2 installation issue
Posted: Fri Jun 29, 2012 2:07 am
by juddc
Folks -- I'm trying to assist a friend in setting up an LC system and he has a copy of Empower2 and it simply will not install. The error message I'm getting follows:
Empower is unable to determine the version of Oracle installed on your computer. The Empower setup will now exit. Thank you.
The OS is XP-pro (SP3) & it's a fresh installation. It looks like an early version of E2.
Any wisdom would be deeply appreciated!
Re: Empower 2 installation issue
Posted: Fri Jun 29, 2012 8:44 am
by aceto_81
Are you sure you have admin rights on the PC?
Are you running a standalone installation?
Ace
Posted: Fri Jun 29, 2012 11:38 am
by juddc
Yes, it is a stand-alone installation and I will check on the latter. You've seen this before?
Posted: Fri Jun 29, 2012 12:08 pm
by juddc
Yes, I do have admin rights. Thanks!
Posted: Fri Jun 29, 2012 3:23 pm
by DR
That's usually a licensing issue. I'd call Waters.
Posted: Sat Jun 30, 2012 3:28 am
by juddc
DR - Perhaps, but I don't think so. The software had never been installed anywhere before.
Posted: Sat Jun 30, 2012 4:33 pm
by DR
In that case, there is probably some sort of anti virus/malware/spam software interfering. If you can disable that, then install, it may work.
Posted: Sat Jun 30, 2012 10:28 pm
by juddc
I've gone one step beyond. I purchased a new HD, am installing Win Xp Pro fresh, then going straight to E2. We shall see..If this doesn't work, then I'm officially out of ideas. I'm much better with hardware and separation development, honestly.
Thanks guys!
Posted: Mon Jul 02, 2012 8:38 am
by aceto_81
+1
There are some known issues of virus scans interfering with running Empower, so why not while installing Empower?
Posted: Thu Jul 05, 2012 4:37 pm
by juddc
Fixed the issue; with a fresh installation of the OS all went smoothly. Thanks to all for their suggestions and to BenW especially for his assistance.
Posted: Fri Oct 05, 2012 3:06 pm
by Klaus I.
Just for completeness, Waters deliver a 'special' Oracle-Client on the supplied medias. Using a generic Oracle installation will cause trouble.
Posted: Sun Oct 14, 2012 4:32 am
by ama1001
yes, that was likely the problem. there was another Oracle installation on the computer.
Posted: Mon Oct 15, 2012 11:56 am
by benW
hey guys, no need to speculate, we fixed this very quickly a while ago... :wink:
