Hi-Plex Ca (Duo) Pressure Problem
Posted: Wed Jun 27, 2012 8:07 pm
Hello, sirs!
Recently, we purchased a Hi-Plex Ca (Duo) column to analyse carbohydrates.
The supplier methodology indicates a 0.6 mL/min flow at 85 ºC. Unfortunatelly our HPLC can't reach this temperature so we tried to do it at 80 ºC, but at this temperature we are unable to exceed a flow of 0.24 mL/min because of the column maximum
allowed pressure (50 bar). Could this 5 ºC diference influence so much the pressure? Can we increase the flowrate in any way?
Thanks for your help!
