Search: Chromatography COLUMN
Posted: Tue May 31, 2005 12:53 pm
I am searching for a chromatography column (Affinity chromatography, gravity flow). The Bead size of my matrix is 45-165µm in diameter --> the column should have a frit with pore diameter of ideally less than 35µm.
Does anybody know a column adapted for easy handling?
Thank you for your help!
Mathilde
Mathilde
