Very simple question; but at the same time annoying..Grammer
Posted: Sat Jun 23, 2012 3:38 pm
This is a very simple question really, but I cannot find the answer anywhere...
If, lets say I am using an LC with a triple quadrupole detector: is the correct abbreviation i) LC-MS/MS ii) LC-MS-MS iii) LCMS iv)LC/MS ???
What is the difference between using a '-'or a '/' to separate two instruments?
Similarly, lets say I am using OFFLINE SPE, then I analyse the samples by LC with UV detection; is the correct abbreviation i)SPE-LC-UV ii) SPE, LC-UV iii) SPE/LC-UV
Does the use of a 'comma' between instruments suggest SPE is offline whereas the '-' suggest is online?
Thankyou for your help.
