Varian Galaxie and Out of Memory Error
Posted: Fri Jun 22, 2012 10:27 pm
by khopcus
I am have trouble using the data analysis package of Varian Galaixe Ver 1.9.302.530. I have two instrumets running this software and can load data files on one of them no problem. The other one spits out an error when I ry and load the method and/or a data file. It says "xxxxx.data could not open : loading error (Out of memory)
Any help would be appreciated.
Keith
Re: Varian Galaxie and Out of Memory Error
Posted: Sun Jun 24, 2012 1:57 am
by HbJ
Well, my first question is: Did it ever work and did you check disk space and fragmentation?
Posted: Mon Jun 25, 2012 12:49 pm
by srattier
I would advise to install Galaxie 1.9SP2B (1.9.302.952) on top of your version. Hopefully it solves your issue.
You can dowload the CDROM here :
https://www.drivercentral.net/product.h ... 35424701b3
Posted: Wed Jun 27, 2012 9:12 am
by dpr
We had a very similar issue a few years ago (@2006) when we istalled Galaxie.
It turned out to be a firmwear issue with the GC.
It would run for a while then when memory buffers where full it fell over.
This was on an early Agilent 6890.
