PLP quantitation carryover
Posted: Tue Jun 19, 2012 8:17 pm
Dear Chromatographers,
I'm trying to reproduce a method for pyridoxal 5-phosphate (PLP) quantitation by LC after derivatisations with semicarbazide+glycine but I'm having some difficulties. After running a plasma sample (HPLC PLP.jpeg)
we ran a mobile phase and we found peaks of contamination (Mobile Phase.jpeg)
. We believe it's carryover from the last run. Please, find attached two chromatograms. Any help will be much appreciated.
Conditions:
isocratic mobile phase for chromatography was 60 mmol/l disodium hydrogen phosphate containing 9.5% methanol (V/V) and 400 mg/l EDTA disodium salt, adjusted to pH 6.5. Column Luna C18 4.6×250 mm. Flow-rate of 1.5 ml/min. excitation (Ex) and emission (Em) wavelengths were 380 and 450 nm, respectively.
Thank you.
Guilherme
. We believe it's carryover from the last run. Please, find attached two chromatograms. Any help will be much appreciated.Conditions:
Thank you.
Guilherme
